FXS qwirkiness..
This is more of a curiosity question than anything.
I've setup an H.323 gateway with 8 FXS/DID ports for faxes. Dialing in and out of the system works fine. But if I'm on one fax line dialing the full 9+7 for one of the other fax lines I get a dialtone.
Is this normal? To prevent dialing an on system number through the PSTN. Or did I miss something in my config?
The dial-peers look like this right now-
dial-peer voice 9712 pots
destination-pattern 9712
Port 0/2/0
Thanks for your input.
Justin
1 REPLY
Hall of Fame Super Gold
Re: FXS qwirkiness..
What can be happending is that you're hitting the default incoming DP that doesn't have "direct-inward-dialing. To prevent that do:
dial-peer voice 1 pots
incoming called-number 1
89
