Community Member
FXS to FXO
Hello All ,
need urgent help please , I have a router with FXS 4 - ports , and we connected them to PBX ( FXO port) , the problem that :
When we place a cll from the network to any ext behind the PBX , all the FXS ports on the router go off-hook , and some times all are off -hook even with out calls
#sh voice port summary
IN OUT
PORT CH SIG-TYPE ADMIN OPER STATUS STATUS EC
0/1/0 -- fxs-gs up up off-hook idle y
0/1/1 -- fxs-gs up up off-hook idle y
0/1/2 -- fxs-gs up up off-hook idle y
0/1/3 -- fxs-gs up up off-hook idle y
we tried to change the signaling to Loop start but with no joy
Do you have any suggestions
Moamen
1 REPLY
Bronze
Re: FXS to FXO
The end-to-end connection between the CO RJ11 jack and the router voice-port must be a straight-through connection. This means that TIP goes to TIP and RING to RING. Normally the CO provides an interface for which a standard rolled RJ11 cable can be used since the connection that results is straight. However, sometimes the CO cannot reverse the pinouts and therefore, a straight RJ11 cable is needed.
http://www.cisco.com/en/US/tech/tk652/tk653/technologies_tech_note09186a0080094fac.shtml
http://www.cisco.com/en/US/tech/tk1077/technologies_configuration_example09186a008009431b.shtml
116
