FXS-to-FXS call disconnect
I have a current problem with my client's ip tel set up, they have three offices HQ, Branch A and Branch B. My problem is after changing their HQ's router from 1760 to 2901, Branch A and B can't call HQ anymore call is drop 2 seconds after the caller finished dialing. However calls from HQ to Branch A and B are successful and calls from Branch A to B and vice versa are also successful. Already tried applying different codecs on the dial-peers, below are my configurations from HQ and Branch A routers.
                                      ***** HQ Router configuration *****
voice-card 0
dspfarm
dsp services dspfarm
dsp allocation signaling dspid
voice call send-alert
voice call convert-discpi-to-prog
voice call carrier capacity active
voice rtp send-recv
voice service voip
ip address trusted list
  ipv4 192.168.0.0
  ipv4 192.168.1.0
  ipv4 192.168.2.0
gcid
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
  cause-code legacy
voice class codec 1
codec preference 1 g723r53
codec preference 2 g723r63
voice class codec 2
codec preference 1 g729r8
codec preference 2 g729br8
voice class codec 3
codec preference 2 g711ulaw
application
global
  service alternate Default
map
  q850-cause 34 q850-cause 17
license udi pid CISCO2901/K9 sn FGL155320RY
license boot module c2900 technology-package datak9
hw-module pvdm 0/0
archive
log config
  hidekeys
redundancy
class-map match-all voip
match access-group 100
policy-map llq2
class voip
  priority 128 2400
  set ip precedence 5
class class-default
  fair-queue
  shape average 512000 5120
policy-map llq
class voip
  priority 128 2400
  set ip precedence 5
class class-default
  fair-queue
  shape average 1024000 10240
gw-accounting syslog
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address 192.168.0.10 255.255.255.0
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip bind srcaddr 192.168.0.10
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0
bandwidth 1024
no ip address
no ip mfib cef input
encapsulation frame-relay IETF
load-interval 30
frame-relay lmi-type ansi
service-policy output llq
interface Serial0/0/0.20 point-to-point
ip address 172.23.251.166 255.255.255.252
frame-relay interface-dlci 20
  class VOFR
interface Serial0/0/1
bandwidth 512
no ip address
load-interval 30
service-policy output llq2
interface Serial0/0/1.939 point-to-point
ip address 10.212.179.70 255.255.255.252
frame-relay interface-dlci 939
  class VOFR2
ip forward-protocol nd
ip pim bidir-enable
ip http server
ip http authentication local
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.168.0.2
map-class frame-relay VOFR
frame-relay cir 1024000
frame-relay bc 10240
frame-relay be 0
frame-relay mincir 1024000
map-class frame-relay VOFR2
frame-relay cir 128000
frame-relay bc 1280
frame-relay be 0
frame-relay mincir 128000
logging 192.168.0.20
access-list 100 permit udp any any range 16384 32767
access-list 100 permit ip any any dscp cs5
access-list 100 permit udp any any dscp ef
access-list 100 permit udp any any precedence critical
snmp-server community public RO
snmp-server enable traps entity-sensor threshold
control-plane
call treatment cause-code no-QoS
voice-port 0/1/0
secondary dialtone
timeouts call-disconnect 5
timeouts wait-release 5
description **** PABX LOCAL 156 *****
voice-port 0/1/1
secondary dialtone
description **** PABX LOCAL 136 *****
mgcp profile default
dial-peer cor custom
dial-peer voice 11 pots
destination-pattern 11...
port 0/1/1
forward-digits 3
dial-peer voice 10 pots
destination-pattern 10...
port 0/1/0
forward-digits 3
dial-peer voice 30 voip
description **** Branch B ****
destination-pattern 3.
session target ipv4:192.168.2.10
voice-class codec 3
req-qos guaranteed-delay audio
ip qos dscp cs5 media
dial-peer voice 20 voip
description **** Branch A ****
destination-pattern 2.
session target ipv4:192.168.1.10
voice-class codec 2
dial-peer voice 110 pots
destination-pattern 110
port 0/1/1
forward-digits 1
dial-peer voice 100 pots
destination-pattern 100
port 0/1/0
forward-digits 1
                                ***** Branch A Router configuration*****
voice rtp send-recv
voice class codec 1
voice class codec 2
voice class codec 3
no voice hpi capture buffer
no voice hpi capture destination
policy-map llq
  class voip
   priority 64
   set precedence 5
  class class-default
   fair-queue
interface FastEthernet0/0
ip address 192.168.1.10 255.255.255.0
speed auto
interface Serial0/0
no ip address
shutdown
no fair-queue
interface Serial0/1
bandwidth 192
no ip address
no fair-queue
frame-relay traffic-shaping
ip rtp priority 16384 16383 64
interface Serial0/1.1 point-to-point
ip address 10.10.15.2 255.255.255.252
frame-relay interface-dlci 25
  class VOFR
ip classless
ip route 0.0.0.0 0.0.0.0 10.10.15.1
ip http server
frame-relay cir 192000
frame-relay bc 1920
frame-relay be 0
frame-relay mincir 192000
access-list 100 permit ip any any precedence critical
snmp-server engineID local 000000090200000216F209DE
snmp-server enable traps tty
radius-server authorization permit missing Service-Type
call rsvp-sync
voice-port 2/0
voice-port 2/1
dial-peer voice 20 pots
destination-pattern 20
port 2/0
dial-peer voice 21 pots
destination-pattern 21
port 2/1
voice-class codec 3
dial-peer voice 10 voip
description ***** HQ *****
destination-pattern 1[0-1]0
voice-class codec 3
session target ipv4:192.168.0.10
dial-peer voice 1000 voip
voice-class codec 3
dial-peer voice 1001 voip
voice-class codec 3
Everyone's tags (1)
1 ACCEPTED SOLUTION
Green
Re: FXS-to-FXS call disconnect
Hi Mike,
You are welcome
Please mark the case as correct answer provided.
Alex
Regards, Alex. Please rate useful posts.
Green
On you HQ router can you post the output of
show ip address trusted list
Alex
hi acampbell,
please see results below:
#show ip address trusted list
IP Address Trusted Authentication
Administration State: UP
Operation State:      UP
IP Address Trusted Call Block Cause: call-reject (21)
VoIP Dial-peer IPv4 Session Targets:
Peer Tag        Oper State      Session Target
30              UP              ipv4:192.168.2.10
20              UP              ipv4:192.168.1.10
40              UP              ipv4:192.168.8.10
82              UP              ipv4:192.168.8.10
80              UP              ipv4:192.168.8.10
IP Address Trusted List:
ipv4 192.168.1.0
ipv4 192.168.2.0
ipv4 192.168.8.0
ipv4 192.168.0.0
Green
On BRANCH A router
can you add the H323 binding to the fast0/0 interface
h323-gateway voip bind srcaddr 192.168.1.10
Also have a look on BRANCH B and bind the H323 there too.
Then retest
Alex
Hi Alex,
After adding some configurations both on Branch A and HQ Router, Branch A can now call HQ however when HQ will call Branch A after 5 secs the call drops. I initiate debug voice ccapi inout on both sides and i got a Disconnect Cause=63 on the HQ Router, which means [Service or option ot available, unspecified.]
               ********** BRANCH A **********
voice rtp send-recv
voice service voip
cause-code legacy
h323
  session transport udp
voice class codec 1
codec preference 3 g711alaw
voice class codec 2
voice class codec 3
policy-map llq
  class voip
   priority 64
   set precedence 5
  class class-default
   fair-queue
speed auto
interface Serial0/0
no ip address
shutdown
no fair-queue
interface Serial0/1
bandwidth 192
no ip address
no fair-queue
  class VOFR
ip classless
ip http server
frame-relay bc 1920
frame-relay be 0
snmp-server community RO
call rsvp-sync
voice-port 2/0
voice-port 2/1
port 2/0
port 2/1
description ****** HQ ROUTER ******
voice-class codec 2
dial-peer voice 100 voip
destination-pattern 1[0-1]...
voice-class codec 2
               ********** HQ ROUTER **********
voice rtp send-recv
voice service voip
  ipv4 0.0.0.0 0.0.0.0
mode border-element
media transcoder sync-streams
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
  cause-code legacy
h323
voice class codec 1
voice class codec 2
voice class codec 3
fax interface-type fax-mail
application
global
hw-module pvdm 0/0
archive
log config
  hidekeys
username trends privilege 15 password 7
redundancy
policy-map llq2
class voip
  set ip precedence 5
  priority 64 2400
class class-default
  fair-queue
policy-map llq
class voip
  priority percent 50
  set ip precedence 5
class class-default
  fair-queue
no ip address
shutdown
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
bandwidth 1024
no ip address
load-interval 30
  class VOFR
bandwidth 512
no ip address
load-interval 30
  class VOFR2
ip pim bidir-enable
ip http server
frame-relay bc 1280
frame-relay be 0
frame-relay be 0
control-plane
voice-port 0/1/0
secondary dialtone
no battery-reversal
no vad
voice-port 0/1/1
secondary dialtone
no battery-reversal
no vad
description *** BRANCH A ***
voice-class codec 2
port 0/1/0
forward-digits 1
port 0/1/1
forward-digits 1
port 0/1/0
forward-digits 3
port 0/1/1
forward-digits 3
Can you please add on your Branch A router, under "voice service voip"  the command:
and test please.
Green
Can you post the debug voice ccapi inout
From the HQ router when you make a call to the BRANCH A
I think your new issue is being caused by incomplete RSVP configuation,
You need to specify an RSVP interface and it is best that your SP network supports RSVP too.
A very complex subject.
I do not think you need to use RSVP at all.
You have configured QOS over your frame relay interfaces - thats good.
If you are trying use the RSVP for CAC to control the number of calls, try using a different method.
This is your existing DP from HQ to BRANCH A
voice-class codec 2
If you are trying to limit this route to say 2 calls then try changing the DP to this:-
voice-class codec 2
no req-qos guaranteed-delay audio
max-conn 2
Do the same at the DP on BRACH A to HQ
Alex
Hi Alex,
It Works! After adding the said configurations on both sides calls are not drop anymore.
Thanks alot,
Mike
Green
Hi Mike,
You are welcome
Alex
854
