Community Member
FXS Voice ports showing off-hook in Cisco 2821
I have installed FXS ports on a 2821 router. Since two days ago they have gone into off-hook status and remained that way. I'm not able to make any calls. Please i need your input to resolve this.
2R#show voice port summary
IN OUT
PORT CH SIG-TYPE ADMIN OPER STATUS STATUS EC
0/1/0 -- fxs-ls up up off-hook idle y
0/1/1 -- fxs-ls up up off-hook idle y
0/1/2 -- fxs-ls up up off-hook idle y
0/1/3 -- fxs-ls up up off-hook idle y
82R#
Re: FXS Voice ports showing off-hook in Cisco 2821
Hi!
Did you try to reload the router and see if the problem is cleared? What happens if you manually do a shut/no shut on the ports? Also check the IOS version, sometimes an upgrade helps if the IOS is too old. Otherwise probably you'll need to replace the cards...
Teresa.
Regards, Tere. If you find this post helpful, please rate! :)
'show voice call summary' ?
430
