FXS without dial tone in CME
Hi!
I have a problem configuring a FXS port in a router 2911 with CME.
After introduce all commands for the configuration, i have not a dial tone, Now the router is not connected with any BRI or PRI, but I think that I should hear a dial tone when an analogic phone where connected, these are the commands:
Voice ports
voice-port 0/1/0
signal groundStart
no echo-cancel enable
echo-cancel mode 1
cptone ES
timeouts ringing infinity
connection plar 2000
bearer-cap Speech
caller-id enable
voice-port 0/1/1
signal groundStart
echo-cancel mode 1
cptone ES
bearer-cap Speech
caller-id enable
SCCP
sccp local GigabitEthernet0/0.10
sccp ccm x.x.x.x identifier 1 version 7.0
sccp
sccp ccm group 1
associate ccm 1 priority 1
Dial-peer association
dial-peer voice 500 pots
service stcapp
port 0/1/0
dial-peer voice 501 pots
service stcapp
port 0/1/1
Do i need anything else??
Thanks!!!!
5 ACCEPTED SOLUTIONS
VIP Super Bronze
Hi, Here is the explanation:
PVDM3-16 = 1dsp
PVDM3-32= 2 dsp
PVDM3-48= 3dsp
PVDM3-64=4dsp
http://www.cisco.com/web/applicat/dsprecal/dsp_calc.html
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Hi Ivan,
Can you try this config to test out:
Remove all the commands under the voice-port:
voice-port 0/1/0
voice-port 0/1/1
Dial-peer association should look like this (remove the extra config)
destination-p 1001
port 0/1/0
destination-p 1002
port 0/1/1
Save config and reload the router if required so that there are no cached values.
Basically any phone should have a line appearence (which is provided by the destination-pattern command on an FXS port. This config is missing in your "show run".
Let me know if this resolves the issue.
Arun Kumar MV
Re: FXS without dial tone in CME
If the voice port turns up you have enough dsp resources. Your CME config is incomplete. First make sure the ip of the Sccp service points to the source address under telephony service. Next show the stcapp device names it's either under stcapp app or Sccp I don't remember off the top of my head. After you get the name add an ephone of type analog and whatever Mac address you got from the last step. Finally add an ephone-dn and assign it to that ephone.
Hall of Fame Super Gold
With service stcapp, you have the port in SCCP mode.
With destination-pattern, in regular dial-peer mode.
The two modes, and commands are mutually exclusive.
Hi Ivan,
Paolo is right. We don't need the destination-pattern command if you are looking to control the analog endpoints via CME. The destination-pattern is for providing an extension number to the analog stations.
However you may use the destination-pattern command to verify the hardware (VIC3 card).
So the correct configuration would be:
voice-port 0/1/0
caller-id enable
cptone ES
voice-port 0/1/1
caller-id enable
cptone ES
stcapp ccm-group 1
stcapp
sccp
sccp ccm group 1
 service stcapp
port 0/1/0
 service stcapp
port 0/1/1
telephony-service
no auto-reg-ephone
max-ephones 50
max-dn 50
ip source-address x.x.x.x port 2000
Other example configuration:
http://www.cisco.com/en/US/docs/ios/voice/fxs/configuration/guide/fxsbasic_ps10592_TSD_Products_Configuration_Guide_Chapter.html#wp1010513
I came across a Cisco Documentation that says that while connecting the RJ11 cable to the VIC3-2FXS/DID, the router has to be powered off:
http://www.cisco.com/en/US/partner/docs/routers/access/interfaces/ic/hardware/installation/guide/2port_FXS_DID_VIC.html#wp1065733
So first enter the configuration commands. Power off the router, connect the RJ11 cable to the phone. Power on the router and check if the Phone has the dial tone.
Arun Kumar MV
Please rate useful posts !!!
Signal must be loop start.
Also, plar commands have no effect for ports in SCCP mode, as well bearer-cap.
Ok thanks, I removed plar and bearer-cap, but although I introduce the loopstart commands in the voice-port,
Router(config)#voice-port 0/1/0
Router(config-voiceport)#signal loopStart
Router(config-voiceport)#exit
Router(config)#voice-port 0/1/1
It stills shows without it, why?
voice-port 0/1/0
echo-cancel mode 1
cptone ES
caller-id enable
voice-port 0/1/1
echo-cancel mode 1
cptone ES
caller-id enable
Because is the default.
Still fails with loopstart, there is not a dial tone.
Thanks.
Check if it works without SCCP first.
Can you send a debug VPm signal of when you go off hook on the voice port with the analog phone. Also you need do a shut no shut to switch port signal type.
Hi!
Thanks for your response, now i hear a tone, but a busy tone, below you can see the debug vpm signal:
RouterMarpetrol#
Aug 21 08:28:24.459: htsp_process_event: [0/1/0, FXSLS_ONHOOK, E_DSP_SIG_1100]fxsls_onhook_offhook htsp_setup_ind
Aug 21 08:28:24.459: [0/1/0] get_local_station_id calling num= calling name= calling time=08/21 10:28  orig called=
Aug 21 08:28:24.459: htsp_pre_connect_disconnect, cdb = 2AC03798 cause = 29
Aug 21 08:28:24.459: htsp_process_event: [0/1/0, FXSLS_WAIT_SETUP_ACK, E_HTSP_PRE_CONN_DISC]fxsls_wait_setup_pre_conn_disc
Aug 21 08:28:32.223: htsp_process_event: [0/1/0, FXSLS_WAIT_SETUP_ACK, E_DSP_SIG_0100]fxsls_wait_setup_onhook
Aug 21 08:28:32.223: htsp_timer - 1000 msec
Aug 21 08:28:33.223: htsp_process_event: [0/1/0, FXSLS_W_SETUP_ACK_ONHOOK, E_HTSP_EVENT_TIMER]fxsls_onhook_setup_ack_timer
Aug 21 08:28:33.223: htsp_timer_stop
Aug 21 08:28:33.223: htsp_process_event: [0/1/0, FXSLS_W_SETUP_ACK_ONHOOK, E_HTSP_RELEASE_REQ]fxsls_wait_setup_release
Aug 21 08:28:35.855: htsp_process_event: [0/1/0, FXSLS_ONHOOK, E_DSP_SIG_1100]fxsls_onhook_offhook htsp_setup_ind
I tested it in both voice port , with the same result, busy tone.
Regards.
I add more information:
Router#sh stcapp device voice-port 0/1/1
Port Identifier:  0/1/1
Device Type:      ALG
Device Id:        3
Device Name:      AN4C1183A598081
Device Security Mode : None
Modem Capability: None
Device State:     OOS
Diagnostic:       None
Directory Number:
Dial Peer(s):     501
Dialtone after remote onhook feature: not activated
Busytone after remote onhook feature: not activated
Last Event:       STCAPP_CC_EV_CALL_SETUP_IND
Line State:       UNREGISTERED    ---------------------------------> This is a normal state for analog phone??
Line Mode:        CALL_BASIC
Hook State:       ONHOOK
mwi:              DISABLE
vmwi:             OFF
mwi config:       Both
Privacy:          Not configured
PLAR:             DISABLE
Callback State:   DISABLED
CWT Repetition Interval: 0 second(s) (no repetition)
Number of CCBs:   0
Global call info:
    Total CCB count      = 0
    Total call leg count = 0
debug voip ccapi inout
Aug 21 08:36:09.071: //-1/17159923801A/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
   cisco-redirectreason=0   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
Aug 21 08:36:09.071: //-1/17159923801A/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x311BAEC0, Call Info(
   Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE,
   Incoming Dial-peer=501, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Aug 21 08:36:09.071: //-1/17159923801A/CCAPI/ccCheckClipClir:
   In: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Out: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Aug 21 08:36:09.071: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Aug 21 08:36:09.071: :cc_get_feature_vsa malloc success
Aug 21 08:36:09.071:  cc_get_feature_vsa count is 1
Aug 21 08:36:09.071: :FEATURE_VSA attributes are: feature_name:0,feature_time:717329400,feature_id:7
Aug 21 08:36:09.071: //7/17159923801A/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=(TON=Unknown, NPI=Unknown))
Aug 21 08:36:09.071: //7/17159923801A/CCAPI/cc_process_call_setup_ind:
   Event=0x3119BBF8
   >>>>CCAPI handed cid 7 with tag 501 to app "stcapp"
Aug 21 08:36:09.071: //7/17159923801A/CCAPI/ccCallDisconnect:
   Cause Value=41, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
   Cause Value=41, Call Entry(Responsed=TRUE, Cause Value=41)
Aug 21 08:36:09.071: //7/17159923801A/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
show voice port summ    (PRI is disconnected)
                                           IN       OUT
PORT            CH   SIG-TYPE   ADMIN OPER STATUS   STATUS   EC
0/0/0:15        01  isdn-voice  down  down none     none     n
0/0/0:15        02  isdn-voice  down  down none     none     n
0/0/0:15        03  isdn-voice  down  down none     none     n
0/0/0:15        04  isdn-voice  down  down none     none     n
0/0/0:15        05  isdn-voice  down  down none     none     n
0/0/0:15        06  isdn-voice  down  down none     none     n
0/0/0:15        07  isdn-voice  down  down none     none     n
0/0/0:15        08  isdn-voice  down  down none     none     n
0/0/0:15        09  isdn-voice  down  down none     none     n
0/0/0:15        10  isdn-voice  down  down none     none     n
0/0/0:15        11  isdn-voice  down  down none     none     n
0/0/0:15        12  isdn-voice  down  down none     none     n
0/0/0:15        13  isdn-voice  down  down none     none     n
0/0/0:15        14  isdn-voice  down  down none     none     n
0/0/0:15        15  isdn-voice  down  down none     none     n
0/0/0:15        17  isdn-voice  down  down none     none     n
0/0/0:15        18  isdn-voice  down  down none     none     n
0/0/0:15        19  isdn-voice  down  down none     none     n
0/0/0:15        20  isdn-voice  down  down none     none     n
0/0/0:15        21  isdn-voice  down  down none     none     n
0/0/0:15        22  isdn-voice  down  down none     none     n
0/0/0:15        23  isdn-voice  down  down none     none     n
0/0/0:15        24  isdn-voice  down  down none     none     n
0/0/0:15        25  isdn-voice  down  down none     none     n
0/0/0:15        26  isdn-voice  down  down none     none     n
0/0/0:15        27  isdn-voice  down  down none     none     n
0/0/0:15        28  isdn-voice  down  down none     none     n
0/0/0:15        29  isdn-voice  down  down none     none     n
0/0/0:15        30  isdn-voice  down  down none     none     n
0/0/0:15        31  isdn-voice  down  down none     none     n
0/1/0           --  fxs-ls      up    dorm on-hook  idle     n
0/1/1           --  fxs-ls      up    dorm on-hook  idle     n
VIP Super Bronze
Do you have the ff: config in your gateway? You have not sent your full config, so I cant tell if you have it or not...
stcapp ccm-group 1
stcapp
Hi!
Yes i have it, I forget to add it,
stcapp ccm-group 1
stcapp
Still receive a busy tone, i keep on looking for which could be the problem
Thanks!
VIP Super Bronze
Do you have DSPs in your router for the analogue cards?
What type of analogue cards do you have?
Can you send a show version and a  show diag.
show version
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.1(4)M4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Tue 20-Mar-12 18:57 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M15, RELEASE SOFTWARE (fc1)
RouterMarpetrol uptime is 1 hour, 39 minutes
System restarted at 10:03:47 VERANO Tue Aug 21 2012
System image file is "flash0:c2900-universalk9-mz.SPA.151-4.M4.bin"
Last reload type: Normal Reload
Cisco CISCO2911/K9 (revision 1.0) with 479232K/45056K bytes of memory.
Processor board ID FCZ162070T9
3 Gigabit Ethernet interfaces
31 Serial interfaces
1 terminal line
1 Channelized E1/PRI port
2 Voice FXS interfaces
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
250880K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO2911/K9         xxxxxxxxxxxxx
Technology Package License Information for Module:'c2900'
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
ipbase        ipbasek9      Permanent      ipbasek9
security      None          None           None
uc            uck9          Permanent      uck9
data          None          None           None
show diag
C2911 Mother board 3GE, integrated VPN and 4W Port adapter, 6 ports
        Port adapter is analyzed
        Port adapter insertion time 01:40:18 ago
        EEPROM contents at hardware discovery:
        PCB Serial Number        : FOC16165JAU
        Hardware Revision        : 1.0
        Part Number              : 73-11833-08
        Top Assy. Part Number    : 800-30797-04
        Board Revision           : D0
        Deviation Number         : 123694
        Fab Version              : 03
        Product (FRU) Number     : CISCO2911/K9
        Version Identifier       : V05
        CLEI Code                : CMMBR00ARC
        Processor type           : C1
        Chassis Serial Number    : FCZ162070T9
        Chassis MAC Address      : a44c.1183.a598
        MAC Address block size   : 80
        Manufacturing Test Data  : 00 00 00 00 00 00 00 00
        EEPROM format version 4
        EEPROM contents (hex):
          0x00: 04 FF C1 8B 46 4F 43 31 36 31 36 35 4A 41 55 40
          0x10: 06 18 41 01 00 82 49 2E 39 08 C0 46 03 20 00 78
          0x20: 4D 04 42 44 30 88 00 01 E3 2E 02 03 CB 8C 43 49
          0x30: 53 43 4F 32 39 31 31 2F 4B 39 89 56 30 35 20 D9
          0x40: 04 40 C1 CB C2 C6 8A 43 4D 4D 42 52 30 30 41 52
          0x50: 43 09 C1 C2 8B 46 43 5A 31 36 32 30 37 30 54 39
          0x60: C3 06 A4 4C 11 83 A5 98 43 00 50 C4 08 00 00 00
          0x70: 00 00 00 00 00 F3 00 03 40 01 25 FF FF FF FF FF
          0x80: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x90: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xA0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xB0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xC0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xD0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xE0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xF0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        Internal Power Supply information
        Top Assy. Part Number    : 341-0235-06
        Deviation Number         : 0
        PCB Serial Number        : DCA1610R2Y5
        RMA Test History         : 00
        RMA Number               : 0-0-0-0
        RMA History              : 00
        Version Identifier       : V04
        Product (FRU) Number     : PWR-2911-AC
        CLEI Code                : 0000000000
        Board Revision           : A0
          0x00: 04 FF 40 05 E5 DF 45 01 55 00 EB 06 88 00 00 00
          0x10: 00 C1 8B 44 43 41 31 36 31 30 52 32 59 35 03 00
          0x20: 81 00 00 00 00 04 00 89 56 30 34 20 CB 8B 50 57
          0x30: 52 2D 32 39 31 31 2D 41 43 C6 8A 30 30 30 30 30
          0x40: 30 30 30 30 30 F3 00 59 41 00 BE 42 00 05 F8 00
          0x50: 50 01 F3 15 97 02 F0 18 3B 03 E6 19 FB 04 E2 1B
          0x60: 1C 05 D9 1C 53 06 D8 1D 4F 07 D6 1D B6 08 CE 1E
          0x70: 40 09 C2 1E ED 0A B8 1F B1 0B B9 20 20 0D AF 20
          0x80: 86 0F 9B 20 ED 11 91 21 3F 13 87 21 62 17 74 21
          0x90: C0 1B 57 21 DB 1F 38 21 F3 23 25 21 FC 27 0A 21
          0xA0: F3 42 41 30 FF FF FF FF FF FF FF FF FF FF FF FF
        PVDM Slot 0:
        16-channel (G.711) Voice/Fax PVDM3 DSP DIMM PVDM daughter card
        Part Number              : 73-11576-03
        Board Revision           : C0
        Fab Version              : 03
        PCB Serial Number        : FOC1617691F
        RMA History              : 00
        Processor type           : 00
        Product (FRU) Number     : PVDM3-16
        Version Identifier       : V01
          0x00: 04 FF 40 05 D8 41 01 00 82 49 2D 38 03 42 43 30
          0x10: 88 00 00 00 00 02 03 C1 8B 46 4F 43 31 36 31 37
          0x20: 36 39 31 46 03 00 81 00 00 00 00 04 00 09 00 CB
          0x30: 8F 50 56 44 4D 33 2D 31 36 20 20 20 20 20 20 20
          0x40: 89 56 30 31 20 D9 02 40 C1 FF FF FF FF FF FF FF
          0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        PVDM Slot 1:
        32-channel (G.711) Voice/Fax PVDM3 DSP DIMM PVDM daughter card
        Part Number              : 73-11577-03
        Board Revision           : C0
        Fab Version              : 03
        PCB Serial Number        : FOC162318BZ
        RMA History              : 00
        Processor type           : 00
        Product (FRU) Number     : PVDM3-32
          0x00: 04 FF 40 05 D9 41 01 00 82 49 2D 39 03 42 43 30
          0x10: 88 00 00 00 00 02 03 C1 8B 46 4F 43 31 36 32 33
          0x20: 31 38 42 5A 03 00 81 00 00 00 00 04 00 09 00 CB
          0x30: 8F 50 56 44 4D 33 2D 33 32 20 20 20 20 20 20 20
        WIC Slot 0:
        VWIC3-1MFT-T1/E1 - 1-Port RJ-48 Multiflex Trunk - T1/E1
        Top Assy. Part Number    : 800-34657-01
        Part Number              : 73-13419-01
        Board Revision           : B0
        Fab Version              : 05
        PCB Serial Number        : FOC162144PM
        Product (FRU) Number     : VWIC3-1MFT-T1/E1
        CLEI Code                : COUIA7PCAA
        RMA History              : 00
          0x00: 04 FF 40 06 ED 41 01 00 C0 46 03 20 00 87 61 01
          0x10: 82 49 34 6B 01 42 42 30 88 00 00 00 00 02 05 C1
          0x20: 8B 46 4F 43 31 36 32 31 34 34 50 4D 89 56 30 31
          0x30: 20 CB 90 56 57 49 43 33 2D 31 4D 46 54 2D 54 31
          0x40: 2F 45 31 C6 8A 43 4F 55 49 41 37 50 43 41 41 03
          0x50: 00 81 00 00 00 00 04 00 D9 03 40 C1 CB FF FF FF
        WIC Slot 1:
        3rd generation - FXS DID Voice daughter card (2 port)
        Top Assy. Part Number    : 800-33587-01
        Board Revision           : D0
        Fab Version              : 08
        PCB Serial Number        : FOC16216B1R
        RMA History              : 00
        Product (FRU) Number     : VIC3-2FXS/DID
        Version Identifier       : V03
        CLEI Code                : IP9IAB3CAC
        Longitudinal Calibration : 01 10 10 82 D6 10 10 8A
                                   52
          0x00: 04 FF 40 06 21 41 01 00 C0 46 03 20 00 83 33 01
          0x10: 42 44 30 88 00 00 00 00 02 08 C1 8B 46 4F 43 31
          0x20: 36 32 31 36 42 31 52 03 00 81 00 00 00 00 04 00
          0x30: CB 8D 56 49 43 33 2D 32 46 58 53 2F 44 49 44 89
          0x40: 56 30 33 20 D9 02 40 C1 C6 8A 49 50 39 49 41 42
          0x50: 33 43 41 43 D3 09 01 10 10 82 D6 10 10 8A 52 FF
Embedded Service Engine 0/0 :
  Total platform memory : 524288K bytes
  Total 2nd core memory : 0K bytes
  Start of physical address for 2nd core : 0x80000000
  Virtual address start of 2nd core memory : 0x0 - 0x0
  2nd core configured disabled
  L2 cache ways for 2nd core : 0
VIP Super Bronze
Ok. From what I can see you should have enough DSPs. Finally can you send a sh run. Please attach in a text file.
I add here because there is not a lot information in the router:
RouterMarpetrol#sh run
Building configuration...
Current configuration : 5085 bytes
! No configuration change since last restart
version 15.1
service password-encryption
hostname Router
boot-start-marker
boot-end-marker
card type e1 0 0
enable secret 4 Tw/TVweCrKP8tReUhD.qT6x6FACDOS52YTSZ8LoMV5A
no aaa new-model
clock timezone ES 1 0
clock summer-time VERANO date Jun 21 2012 0:00 Sep 20 2012 0:00
network-clock-participate wic 0
no ipv6 cef
ip source-route
ip cef
stcapp ccm-group 1
stcapp
isdn switch-type primary-net5
voice-card 0
dspfarm
dsp services dspfarm
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
  call start slow
sip
  redirect contact order best-match
voice class codec 100
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
voice translation-rule 1
rule 1 /-------/ /6201/
voice translation-profile PSTN
translate called 1
license udi pid CISCO2911/K9 sn ---------------
license accept end user agreement
license boot module c2900 technology-package uck9
hw-module pvdm 0/0
hw-module pvdm 0/1
username Marpetrol
redundancy
controller E1 0/0/0
pri-group timeslots 1-31
description PRIMARIO DE VOZ
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
interface GigabitEthernet0/0.10
encapsulation dot1Q 10
ip address x.x.x.x 255.255.255.0
interface GigabitEthernet0/0.20
encapsulation dot1Q 20
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
ip address 192.168.10.1 255.255.255.0
duplex auto
speed auto
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
no cdp enable
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip http path flash:/gui
ip route 0.0.0.0 0.0.0.0 x.x.x.x
control-plane
voice-port 0/0/0:15
echo-cancel mode 1
cptone ES
shutdown
bearer-cap Speech
voice-port 0/1/0
echo-cancel mode 1
cptone ES
caller-id enable
voice-port 0/1/1
echo-cancel mode 1
cptone ES
caller-id enable
mgcp profile default
sccp
sccp ccm group 1
dspfarm profile 2 transcode
codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
maximum sessions 2
associate application SCCP
shutdown
dspfarm profile 1 conference
codec g729br8
codec g729r8
codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
maximum sessions 2
dspfarm profile 3 mtp
codec g711ulaw
maximum sessions hardware 3
shutdown
dial-peer voice 1 pots
translation-profile incoming PSTN
preference 1
incoming called-number .
port 0/0/0:15
dial-peer voice 2 pots
description salientes a moviles
destination-pattern 6........
port 0/0/0:15
forward-digits all
dial-peer voice 10 pots
description salientes a fijos nacionales
destination-pattern 9........
port 0/0/0:15
forward-digits all
dial-peer voice 50 pots
service stcapp
port 0/0/0:15
service stcapp
port 0/1/0
service stcapp
port 0/1/1
dial-peer voice 100 pots
description llamadas internacionales
destination-pattern 0T
port 0/0/0:15
forward-digits all
gatekeeper
shutdown
telephony-service
no auto-reg-ephone
max-ephones 50
max-dn 50
max-redirect 20
system message Marpetrol
user-locale ES
network-locale ES
load 7942 sccp
load 7962 sccp
time-format 24
date-format dd-mm-yy
keepalive 15
max-conferences 8 gain -6
moh music-on-hold.au
transfer-system full-consult
transfer-pattern ....
secondary-dialtone 0
xmltest
create cnf-files version-stamp 7960 Aug 21 2012 11:51:23
line con 0
password 7 0123031049040A
login
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
password 7 13351206190308
login
transport input all
line vty 5 15
password 7 1427171F1E0B26
login
transport input all
scheduler allocate 20000 1000
end
thanks!!!
VIP Super Bronze
I have used the DSP calcultaor to check how many DSPs you need for your current configuration. 30 E1 channels, 2 High codec complexity conference session and 2 FXS ports. The result came up as 4 DSPs..i.e pvdm3-64. From your sh diag, you only have 3 dsps, i.e pvdm3-16 + pvdm3-32.
What you can do to confirm if this is a PVDM related issue is to shutdown the conference dspfarm profile. That will free up dsps. You can test the analogue ports again. If it works this time, then you know you need more DSPs
Hi!
I shutdown the conference dspfarm profile but stills fails, may be is other thing:
Router(config)#dspfarm profile 1
Router(config-dspfarm-profile)#shut
Disabling profile will disconnect active CONFERENCING calls,
do you want to continue ? [yes/no]yes
Still I receive a busy tone , please could you send me link the the DSP calculator? and, other question why pvdm3-16 + pvdm3-32 give me 3 DSP? and 3-64 give me 4?
Thanks!!
VIP Super Bronze
PVDM3-16 = 1dsp
PVDM3-32= 2 dsp
PVDM3-48= 3dsp
PVDM3-64=4dsp
Thanks for your help!
Could resolve this issue if I upgrade the IOS?
regards!
Hi Ivan,
voice-port 0/1/0
voice-port 0/1/1
destination-p 1001
port 0/1/0
destination-p 1002
port 0/1/1
Arun Kumar MV
Cisco router do not need reload after configuration changes.
That does not create a line appearancebut only support for basic calling. True line appearance for analog phones in CME is done configuring the port in SCCP mode, that is what the OP had , at least partially, in the initial posted config
Hi arunkum3 !!
Now I have a dial-tone, even with this configuration in voice-port:
voice-port 0/1/0
echo-cancel mode 1
cptone ES
caller-id enable
voice-port 0/1/1
echo-cancel mode 1
cptone ES
caller-id enable
Question is about destination-p in the dial-peer, i have tested when i quit the command ´service stcapp´ and put destinattion-pattern runs, so the problem was there. my question are:
Why do i must to quit this? in cisco.com explains this command is mandatory
The destinattion-pattern 1001 and 1002 why? is as example, can i put there whatever?
thanks and regards!!!!!
Hi Ivan,
voice-port 0/1/0
caller-id enable
cptone ES
voice-port 0/1/1
caller-id enable
cptone ES
stcapp ccm-group 1
stcapp
sccp
sccp ccm group 1
 service stcapp
port 0/1/0
 service stcapp
port 0/1/1
telephony-service
no auto-reg-ephone
max-ephones 50
max-dn 50
Arun Kumar MV
Hi again!
I did the changes you said me but when I put ´service stcapp´ in a dial-peer sounds always a busy tone in the analog phone, the finally configuration is as below:
card type e1 0 0
no logging console
no aaa new-model
no ipv6 cef
ip source-route
ip cef
stcapp ccm-group 1
stcapp
voice-card 0
dspfarm
voice service voip
h323
  call start slow
sip
license udi pid CISCO2911/K9 sn FCZ162070T9
hw-module pvdm 0/0
hw-module pvdm 0/1
redundancy
controller E1 0/0/0
no ip address
shutdown
no ip address
duplex auto
speed auto
ip address 10.7.5.4 255.255.255.0
ip address 212.4.110.10 255.255.255.0
no ip address
shutdown
duplex auto
speed auto
duplex auto
speed auto
no ip address
encapsulation hdlc
no cdp enable
ip http server
control-plane
voice-port 0/0/0:15
echo-cancel mode 1
cptone ES
shutdown
bearer-cap Speech
voice-port 0/1/0
echo-cancel mode 1
cptone ES
caller-id enable
voice-port 0/1/1
echo-cancel mode 1
cptone ES
caller-id enable
sccp ccm 10.7.5.4 identifier 1 version 7.0
sccp
sccp ccm group 1
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
maximum sessions 2
shutdown
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 2
shutdown
codec g711ulaw
shutdown
preference 1
port 0/0/0:15
port 0/0/0:15
forward-digits all
port 0/0/0:15
forward-digits all
service stcapp
port 0/1/0
service stcapp
port 0/1/1
gatekeeper
shutdown
telephony-service
no auto-reg-ephone
max-ephones 50
max-dn 50
ip source-address 10... port 2000
max-redirect 20
user-locale ES
network-locale ES
load 7942 sccp
load 7962 sccp
time-format 24
keepalive 15
web admin customer name Petrol password Petrol
xmltest
create cnf-files version-stamp 7960 Aug 22 2012 10:24:30
The webpage you send me is the same pdf file from cisco i used, so the first configuration was fine, the only runs is change stcapp in the dial-peer for destination-pattern.
As i will use this with a CME, is there any problem if I live the dial-peer with destination-p in order to get it runs instead of service stcapp??
And the destination-p number could be any number? or must be the telephony number of the analog phone?
Thanks Arunkum and Paolo!
Hi!
All runs properly now, the destinattion-p number is used as the extension of the analog phone.
So question is, what is used for the ´stcapp service´ ???
thanks!
Un saludo.
To have an analog phone access features that otherwise it doesn't have.
Thanks for the nice rating and good luck!
2776
