Community Member
G.711 and G.729 Codec between sites
can any one tell me how to configure G.711 and G.729 Codec between two different Branch Sites ???
Re: G.711 and G.729 Codec between sites
configure a region for each site, assign the region to a device pool, assign DP to devices. configure the codec between regions to be G729
I'd recommend you to fully read the CUCM admin guide and also features and services guide
java
if this helps, please rate
java
www.cisco.com/go/pdi
Community Member
ok
gr8 thanks java ...
246
