Community Member
G.729 IVR prompts on ISR
hi, all!
Did anybody recorded *.au prompts for ISR with G.729 payload?
I got a pretty headache trying to find the way to record or convert existing prompts to G.729...
Help will be very appreciated, thanks!
Hall of Fame Super Gold
Re: G.729 IVR prompts on ISR
Hi, already replied in another thread.
Cisco recommends "cooledit". Other SW may do as well.
Community Member
Hi, thanks, will try it also.
Now i'm leeching Sound Forge.
Community Member
no results.
neither "cooledit" nor "sound forge" has no capability to save G.729 encoded files.
maximum result achieved - i have clean G729 encoded bitstreams created by asterisk's converter or using tools from here: http://www.voiceage.com/openinit_g729.php
These files has no AU headers thus no playable by IOS.
Two another variants: use this http://www.ciscounitytools.com/HelpFiles/SetWAVFormat.htm tool, which requires Unity on windows (I have no Unity) ot to use built-in to CCM4 MOH transcoder (I have no CCM4).
may your recorder.tcl be used for this with incoming call thru g729 dial-peer?
thanks for your help.
At least for cooledit, that incorrect. As I wrote in a previous post, the conversion is not done with "save as", instead you've so select all the stream, then hit F11 that activates the actual recoding. You see a progress window and it takes a little time.
If you changed the header format to g.728 in recorder.tcl, it should record a g.729 call as so, but I never tried that.
Community Member
Sorry, I cannot find the way to save 729 from cooledit...
Maybe vesrion? I have 2.1.
F11 button only allows resampling but not recoding to 729.
Community Member
Finally i got the result using au_convert.exe utility from Cisco TAC.
This is the only way to do this as I see.
Community Member
Is there any chance to find the au_converter.exe on the CCO or on internet?
Thank you for your help.
Community Member
Give me your e-mail, I will send you the file.
Community Member
Thank you for the quick answer.
Email is echaubet@evagroup.fr
Many thanks.
Hi, please can you send file to me ttemir08@yahoo.com
Community Member
Hi, could you send .exe file to benito_albertoc@hotmail.com
Thanks!
Community Member
Hi Ilyaavers,
Please send me your au_convert.exe file. My email address is: zipho.ntanzi@gmail.com
Thank you.
Community Member
Hi, Could you send .exe file to jgml.chrome@gmail.com
Thank you.
Does anyone has the au
Does anyone has the au_convert.exe file?  Please email it to me at levpham@cisco.com.
Customer is looking for this file.
Thank you in advance.
Le,
Community Member
Hi Le,
Hi Le,
Email sent from echaubet@digitalevidence.fr.
Regards.
Eric
919
