g711 to lan and g729 to wan
Hello sirs!
I would like to use g.729 to my voip server on wan and g711 over the "inside lan phones", but where can I explict this? I am using cca, but didnt find. Maybe over CLI. But where could I put this?
Thanks so much!
1 ACCEPTED SOLUTION
Bronze
    You can specify the codec on the gateway(normally a router), for example like as below.
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
codec preference 3 g711alaw
Please rate if this helps, by clicking the stars below.
Bronze
voice class codec 1
Hi Kaja, thanks for reply, but how can I fix the 711 just for call inside of lan and 729 to pstn/voip calls ?
Thanks a lot!
Bronze
With the introduction of Cisco IOS Software Release 12.0(5)T, Cisco VoIP gateways support the codec negotiation feature. This feature provides the ability for a Cisco VoIP gateway to connect to other VoIP devices without necessarily knowing which codec is used for a call-setup. Also, this feature allows Cisco VoIP gateways to dynamically adjust to changes on remote devices. As long as the codec used by the remote VoIP device matches the capabilities-list of the Cisco VoIP gateway, the VoIP call is completed.
     Since G.729 is the default codec for dial-peers, calls would use g729 by default across the WAN.  However Inorder to use the local calls to use G711 we configure as I mentioned and  apply the command "voice class codec 1" at the inbound dial-peers.
Please rate if it helps, by clicking the stars below.
wOw, very nice explanation!
Thanks a lot man!!
367
