g723 support on 3640 with NM-HDV-1E1
nkariyawasam
I am trying to create dial-peers to use g723 on 3640 router with NM-HDV-1E1, running 12.2 IP Plus image. But it doesn't seems to support this codec. Have anybodu tried this combination before ?
allan.thomas
Level 8
Level 8
I have not specifically used this codec with the NM before, but g723 is definately supported.
There are two different NM-HDV-1E1 modules and depending which one you have determines the number of Channels available for High and Medium codec complexity.
Take a look at the following information I found in the document:-
http://www.cisco.com/en/US/products/hw/routers/ps274/products_data_sheet09186a0080091f6f.html
NM-HDV-1E1-30
Single-port, 30-channel E1 voice/fax Network Module (supports 30 channels of medium complexity VoCoders: G.729a/b, G.726, G.711 and fax or 12 channels of G.726, G.729, G.723.1, G.728, G.729a/b, G.711 and fax)
NM-HDV-1E1-30E
Single-port, enhanced 30-channel E1 voice/fax Network Module (supports 30 channels of high and medium complexity VoCoders: G.729a/b, G.726, G.729, G.728, G.723.1, G.711 and fax)
If you require G723, then you will only be able to have 12 Channels, ensure that you have configured the appropriate codec complexity.
Hope this helps.
Allan.
