07-11-2007 09:52 AM - edited 03-14-2019 10:29 PM
Can Cisco call manager support g726 call from PBX to ip phones?Assuming there are hardware transcoders. I do not see g726 available in the region setting.
07-11-2007 02:31 PM
Unfortunetaly, callmanager application does not have the option to choose g726 codec as you already know. But if you exactly tell me the application you are using to integrate with callmanager and what the network topology you have i might figure a possible workaround for you.
07-12-2007 12:20 PM
Currently customer has the following scenario:
PBX-PRI-R0--IP--R1-PRI-PBX
G726 is the codec in the IP cloud. Now CCM will be brought into the scenario and IP Phone needs talk to PBX phones.
Since CCM does not support G726 there will be a problem between the IP phones to PBX phone, right?
07-15-2007 07:11 PM
Correct, you may put another device in the middle. That do the transcoding inside the box like any Linux PBX (*).
07-16-2007 07:51 AM
I have another solution now:
add a 2nd codec prefernece G729 on the gw dial peer so that it can use this codec prefrerence to establish call with CCM which has G729 for IP Phones. Is this good?
