g726 Codec on Cisco Unified Communications Manager and CMExpress
Dear Community,
I have been requested to explore the possibility of using G.726 codec within and between regions on Corporate Telephony System that involves CUCM8.5, CUCM6.1 and a couple of Call Manager Express.
I was wondering if g726 is available on the CUCM, since on the Region field under the Max Audio Bit Rate drop down list, g726 is not listed. Is it supported and if not am I missing something?
It seems strange to me not to be listed, since for example on a Call Manager Express (other site) we have the option to list the codecs as following:
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
codec preference 4 g729br8
codec preference 5 g726r32
Apologies if I am missing something,
Many thanks for your prompt responses!!
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
G.726 is not a good choice because is not supported by the phones.
G.729 or Ilbc if you have phones supporting it, are the best options for low bandwidth.
Paolo thanks a lot for your prompt reply.
Kind regards,
George
918
