Community Member
G729 codecs
Setting up a G729 H323 site I notice under voice class codec or the voip dial-peer config I can only select:
G729r8 or g729br8
Under the conference or transcoder profiles I can select all variations of g729:
g729abr8 G.729ab 8000 bps
g729ar8 G.729a 8000 bps
g729br8 G.729b 8000 bps
g729r8 G.729 8000 bps
Does this mean I can only use g729 or g729ab across the WAN?
Steve
1 REPLY
Hall of Fame Super Gold
Re: G729 codecs
No.
Having Annex "a" support, gives a lighter computational algorithm of "a". The GW do select that automatically, depending on the platform and the "dsp complexity" chosen, where applicable. Basically, you don't need to worry about it.
Annex "B", is a sophisticated VAD scheme embedded in the codec, that cannot be disabled. don't select g729br8 unless you really need to save bandwidth (not much people like VAD anyway).
Annex A & B can also coexist.
177
