Community Member
G729 H323 Gateway
Does a H323 gateway support g729 for outbound calls? If it does can I have calls go out both g711 and g729 if needed?
Re: G729 H323 Gateway
sure it dose
the default pots dial peer codec is g711
and voip g729
u can change it on dial-peer it self
if helpful rate
Community Member
When I set my test phone to use g711 that call works fine. When I set the phone to use g729 I get a busy siginal. Can I setup a POTS dial peer to use either g711 or g729. Or can I setup a POTS dial peer that use just g729
the PSTN only use g711 !!
g729 used over IP WAN connections for less bandwidth
however u might need Xcoding resources for trnscoding between two codecs
but if use pots for pstn why u try to use g729!!
Silver
Please post more detail of what you are trying to do and with what. Are you using an H.323 phone or a SIP phone? Maybe an ATA?
You can not change the codec on a pots dial-peer. If the pots interface is an FXO or FXS, there is no codec--it's not digital. If using a T1 or E1 on your POTS dial-peer then that interface can ONLY use G.711.
266
