Community Member
G729 to H323
I have a new region setup on my call manager where I am setting phones from a branch. In the event that the local PRI goes would like to reroute calls out my HQ gateway. The HQ gateway is H323 and works with outbound calls from our default regions. By default those calls are g711 the calls from my branch region are g729. How can get calls from my g729 region to go out the h323 if needed?
1 REPLY
Community Member
Re: G729 to H323
You can manually change (at the time of failure) your route pattern to point to the gateway or routelist.
100
