G729r8 to G711
Is it possible to transcode 3 simultaneous calls from G729r8 to G711 without any DSP modules. I have Cisco 2811 , IOS 12.4(13r)T11, 2 x VWIC2-1MFT-T1/E1 cards. In other words how many calls can I transcode between this 2 codecs with Cisco 2811 internal resources?
Thank you.
G729r8 to G711
no transcoding without DSPs
VIP Super Bronze
G729r8 to G711
Roman,
You need DSP for transcoding...
To know how many DSP you need you can use the cisco dsp calculator here..
http://www.cisco.com/cgi-bin/Support/DSP/cisco_prodsel.pl
Note: you need CCO login.
For the updated dsp calculator with PVDM3 , you can also access it here: http://www.cisco.com/go/tools --> Just look for DSP calculator
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
G729r8 to G711
Also, you need PVDMs to enable those 2 VWICs assuming you're going to use them.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
G729r8 to G711
unless he uses them for channel-groups and runs voip over data
326
