Gatekeeper Alias Static Command with Priority
I am using Gatekeeper to control calls between a CallManager cluster and CME. When using the alias static command in gatekeeper, calls to CCM phones load balance between the Sub and the Pub. I cannot find a way to implement a priority as you can with the zone prefix command. Anyone know how to implement priorities on the alias static command?
Thanks!!!
Adam
Bronze
Re: Gatekeeper Alias Static Command with Priority
No, you cannot set priorities in the alias static command. For more information kindly refer the following url,
http:/www./cisco.com/en/US/products/sw/iosswrel/ps1835/products_configuration_guide_chapter09186a0080080a52.html#wp1043867
Thanks for the response. I was thinking there was not a way, but needed to ask.
So now let's approach this scenario from the other side. The Gk has an alias static from a remote H323 device (CME in the case). Since you cannot register CME to the Gk because he has an alias static, how do you get calls from CME into the GK destined for other sites?
Thanks!!!
Adam
150
