Community Member
gatekeeper call routing
I am working with a new customer that had much of the install by another vendor, they have 2 gatekeepers, and a handleful of h323 gateways.  It looks like all the dial peers are in the gateways not the gatekeeper, which from what I understand is backwards???  Also, we route calls from CUCM to ICM and CVP applications, I see in CUCM the route pattern pointing to the gatekeeper trunk, but do not understand how the gatekeeper know what to do with the calls.  Any ideas?
Re: gatekeeper call routing
I'd recommend you to read this:
Understanding Cisco IOS Gatekeeper Call Routing
http://www.cisco.com/en/US/partner/tech/tk1077/technologies_tech_note09186a00800a8928.shtml
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Community Member
Thanks for the link, here is the only config in our gatekeeper
gw-type-prefix 1#* default-technology
no shutdown
endpoint max-calls h323id x.x.x.x
Would this route any calls to this IP?  I don't see where we are telling the numbers in CUCM to have a prefix of 1
Hall of Fame Super Silver
Hello Seaman0555,
the CUCM will register to the gatekeeper as a gateway (terminal type gateway)
the line gw-type-prefix 1#* default-technology  on GK
means that for all gateways registering without providing prefixes 1#* is assumed as the prefix
the H.323 trunk is a communication channel between CUCM servers and the gatekeeper where H.225 RAS messages are exchanged in order to perfom endpoint resolution. RAS = resolution Admission Status
Hope to help
Giuseppe
208
