Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Gatekeeper RAS QOS - Gateways and Gatekeeper
I have been searching around trying to find a decent solution to the above, without much luck.
Is there an approach to setting the RAS QOS on gateways and gatekeeper. The default is 0x0 which is not good.
Using an ACL seems like a very clunky approach, is there any other way?
Steve
Re: Gatekeeper RAS QOS - Gateways and Gatekeeper
try to put the foolowing command under the ras dial-peer
dscp siignalling cs3
hope this helps
Thanks, you are correct that does do some QOS. However there are still gaps on both the gateway and the gatekeeper.
I worked out a solution.
328
