Gatekeeper sending DRQs
Hi!
Can anyone tell me under which conditions a Cisco gatekeeper might be forcing a call down between two endpoints (Disengage Reason = forcedDrop?
The call is running fine for 15 minutes, and then BAM! It gets disconnected.
Sniffer traces show that the disconnect is sent by the gatekeeper without a previous event from any endpoint.
Can anybody help?
Best Regards,
Ariel
Green
Re: Gatekeeper sending DRQs
Can we get debug h225 asn1, debug ras debug gatekeeper main 10
to find out
Also more details of the topology?
Any FW?
IOS versions
Exactly at 15:00 ? this may be a time rissue
Try
(config-gk)#timer irr period (increase it)
or
(config-gk)# no irq global-request
Hi, Gonzalo.
The gatekeeper sits in the middle of a network with many PBXs, but is showing this behaviour only when handling a call between a Nortel BCM400 and another PBX (a second Nortel BCM400 or an Avaya). The PBXs are attached directly to the nework, with an IP Network Adapter.
IOS version is 12.4.(3a)
If anyone stumbles upon this thread. I found the reason. It turned out to be that the Nortel BCM400 did not support the IRQ (Information Requests) that the Gatekeeper sends to try to get information on an active call (when the participating gateway does not update the call info itself.)
As the PBX does not support this message, the gatekeeper sent a DRQ to Nortel after 3 unsuccesful IRQ attemps (12 minutes), that then complied and dropped the calls.
488
