Gatekeeper trunk Register on port 1720
How can I force a Gatekeepr controlled trunk to register to gatekeepr with TCP port 1720.
Looks like it just picks up a random port.
Hall of Fame Super Silver
Re: Gatekeeper trunk Register on port 1720
Set the "Trunk That Will Use Port 1720 :" CCM service parameter to the trunk that you want to use (you may only use one) as well as the "Host Name/IP Address of GK That Will Use RAS UDP Port 1719 :" paramter to point to the GK.
HTH,
Chris
I have multiple Gatekeepr trunks.
How can I do this in this situation?
Unfortunatelly, you may only use one of them with port 1720 (as far as I know) :-(
Chris
What will Happen to the other tunks, if i set this up for On trunk in the service parameter?
It is a global configuration. So it might cause the others to have issues.
Thats is what my worry is!
155
