Gatekeper issue
Hi all,
I'm beginner for  Cisco Voice technology.
I have problem with gatekeeper and CUCM.
CUCM --> Gatekeeper <-- gateway.
From sh gatekeeper endpoint, CUCM and gateways are registered.
Call from gateway (E.164) to gateway (E.164) via gatekeeper is successfull.
If I call from CUCM or to CUCM then the result is failed.
Ext number at CUCM (Using ATA device)    : 3xxxx
Ext number at gateway (E.164)                  : 3xxxx
My configuration :
gatekeeper
zone local branch cisco.com 10.10.10.1
zone prefix branch .....
no shutdown
Gateway :
interface Loopback0
ip address 1.0.0.5 255.255.255.255
h323-gateway voip interface
h323-gateway voip id branch ipaddr 10.10.10.1 1719
h323-gateway voip h323-id branchA@cisco.com
h323-gateway voip bind srcaddr 1.0.0.5
dial-peer voice 300 voip
destination-pattern .T
session target ras
tech-prefix 1#
CUCM:
Trunk to gatekeeper     : H.225 Trunk (Gatekeeper Controlled)
technology Prefix         : 1#
Route pattern              : 3xxxx
- If I call from CUCM or to CUCM then the result is failed.
- debug gatekeeper main 10 --> call from gateway (E.164) to CUCM :
Jan  2 10:17:44.910: //5105F7528170/5106937A8172/GK/rassrv_get_addrinfo: (1#55553) Matched tech-prefix 1#
Jan  2 10:17:44.910: //5105F7528170/5106937A8172/GK/rassrv_get_addrinfo: (1#55553) Matched zone prefix  and remainder 55553
Jan  2 10:17:44.910: //xxxxxxxxxxxx/xxxxxxxxxxxx/GK/gk_rassrv_get_ingress_network: ARQ non-std ingress network = 1
Jan  2 10:17:44.910: //5105F7528170/5106937A8172/GK/rassrv_arq_select_viazone: about to check the source side, src_zonep=0x49A20510
Jan  2 10:17:44.910: //5105F7528170/5106937A8172/GK/rassrv_arq_select_viazone: matched zone is branch, and z_invianamelen=0
Jan  2 10:17:44.914: //5105F7528170/5106937A8172/GK/rassrv_arq_select_viazone: about to check the destination side, dst_zonep=0x49A20510
Jan  5 10:17:44.914: //5105F7528170/5106937A8172/GK/rassrv_arq_select_viazone: matched zone is branch, and z_outvianamelen=0
Are there any wrong configuration ?
Alex
Hall of Fame Super Silver
Gatekeper issue
Is there a reason you have the GK in between your GWs and CUCM?
I suggest you perform all routing with tech prefix, there are some good examples in SRND and CCO.
HTH,
Chris
Gatekeper issue
The reason is because I have 20 gateways.
GK#sh gatekeeper gw
GATEWAY TYPE PREFIX TABLE
Prefix: 1#*
  Zone branch master gateway list:
    20.20.20.1:50649 CUCM
Gatekeper issue
Right, but your routing does not include the tech prefix.
Are the GWs all different phone systems, i.e. CME?  If they are all remote sites of off CUCM then why not register them all to it? You can have thousands of GWs on CUCM.
Chris
Gatekeper issue
Hi Chris
All GWs are routers (branches). All GWs registered at gatekeeper endpoints.
CUCM and remote sites have the same ext, start with 3xxxx.
Yes I can register all remote sites into CUCM. But how about remote sites? In six months, I will have 200 remote sites. My customer want to use only one dial-peer installed at all remote sites to make calls to all ext (CUCM and all remote sites).
Previously I add "gw-type-prefix 1# default-technology" at gatekeeper, But I still face the problem
Gatekeper issue
I don't follow exactly, I have never seen such a design and I've been doing this since CM 3.1 days.  So, all remote locations are basically locations of off centralized CUCM deployment, yet you register them to GK rather than directly to CUCM?
How do you handle PSTN ingress and egress routing?
I don't follow how you minimize dial peer configuration, you should not need any dial peers on GW pointing to other remote locations as typically you would only have incoming PSTN calls arriving to the GW and those would simply need to be directed to CUCM (instead of GK).
I must be missing somthing here as the design puzzles me.
GK would be useful if you had multiple phone systems, i.e. few CUCM clusters, bunch of CMEs or other PBXes.
Chris
Gatekeper issue
Hi chris,
It's for VoIP implementation only. All GWs and CUCM are registered to GK.
Thanks.
336
