Attention: The Cisco Support Community site will be in read only mode on Dec14, 2017 from 12:01am PST to 11:30am for standard maintenance. Sorry for the inconvenience.
Gateway and Trunk
I need to know when I should configure gateway and when I shoul configure Trunk?
Re: Gateway and Trunk
" The basic function of a gateway is to translate between different types of networks. In the data environment, a gateway might translate between a Frame Relay network and an Ethernet network, for example. In a VoIP environment, voice gateways are the interface between a VoIP network and the public switched telephone network (PSTN), a private branch exchange (PBX), or analog devices such as fax machines"  source " Cisco Voice Gateways and Gatekeepers"
while the trunk is a logical link used for sending or terminating a voice call
for example you can have a SIP trunk that terminate on a voice gateway
or you may have a voice gateway define as h323 that connect to PSTN using for example ISDN
and you have an other PSTN link through a sip trunk direct from the callmanger to the Teleco using SIP trunk between the CCM and the Telco
these only simple possable scenarios to show the differences between a trunk and a gateway
if helpful Rate
Actually the main reason of my question related to presence server
In presence server I shoud define the CCM as Presence Gateway and on the CCM I should create SIP Trunk
And also you have to define CUPS as an Application Server in CUCM. This is done in System->Application Server.
Hope this helps.
-- Adrián.
I know that I did Presence many times.
What I mean why we use gateway in Presence and Trunk in CCM
398
