@Gateway and WAN?
If we have 2 gateway which card we will use to connect them over WAN?
Re: @Gateway and WAN?
I will use WIC or VWIC ?
That all depends, WIC is just for data, while VWIC supports both voice and data. So actually you would be able to use either of them over the WAN, depending on your other requirements. What type of circuits do you have?
Hope that helped, if so please rate.
If we use T1 line what which card we will use?
A normal WIC is fine for IP Voice, its just IP packets youre sending, same as data.
92
