09-22-2013 01:33 PM - edited 03-16-2019 07:29 PM
I am trying to config my 2621 to be a gateway for my CUCM 7.0. But I can seem to get them to work. On my CUCM do I need to select the router or H.232? Please help:
CCM-Manager Debug
*Mar 1 00:57:37.726: cmapp_xml_process_timer:
*Mar 1 00:57:37.726: cmapp_xml_find_ep_by_name: Checking for ep_name [*]
*Mar 1 00:57:37.726: cmapp_xml_exec_fsm: Endpoint is [*]
*Mar 1 00:57:37.726: cmapp_xml_exec_fsm: endpoint = * state = CMAPP_XML_FILE_DNLD, event = CMAPP_XML_EVT_FILE_DNLD_TIMER
*Mar 1 00:57:37.726: cmapp_xml_file_retry_timer_expired: state = CMAPP_XML_FILE_DNLD, event = CMAPP_XML_EVT_FILE_DNLD_TIMER
*Mar 1 00:57:37.734: cmapp_xml_tftp_download_file: Unable to read file tftp://192.168.1.245/VoiceGateway.jjkkcc.com.cnf.xml, rc=-2
*Mar 1 00:57:37.734: cmapp_xml_get_xml_file: Could not read file tftp://192.168.1.245/VoiceGateway.jjkkcc.com.cnf.xml, len = 0
*Mar 1 00:57:37.734: cmapp_xml_tftp_download_file: Unable to read file tftp:///VoiceGateway.jjkkcc.com.cnf.xml, rc=-2
*Mar 1 00:57:37.738: cmapp_xml_get_xml_file: Could not read file tftp:///VoiceGateway.jjkkcc.com.cnf.xml, len = 0
*Mar 1 00:57:37.738: cmapp_xml_tftp_download_file: Unable to read file tftp:///VoiceGateway.jjkkcc.com.cnf.xml, rc=-2
*Mar 1 00:57:37.742: cmapp_xml_exec_fsm: New state = CMAPP_XML_FILE_DNLD, ep = 8487CDB0
CCM Manager
MGCP Domain Name: jjkkcc.com
Priority Status Host
Primary Registering with CM 192.168.1.245
First Backup None
Second Backup None
Current active Call Manager: None
Backhaul/Redundant link port: 2428
Failover Interval: 30 seconds
Keepalive Interval: 15 seconds
Last keepalive sent: 00:39:38 UTC Mar 1 2002 (elapsed time: 00:20:42)
Last MGCP traffic time: 00:59:57 UTC Mar 1 2002 (elapsed time: 00:00:23)
Last failover time: None
Last switchback time: None
Switchback mode: Graceful
MGCP Fallback mode: Not Selected
Last MGCP Fallback start time: None
Last MGCP Fallback end time: None
MGCP Download Tones: Disabled
TFTP retry count to shut Ports: 2
Configuration Auto-Download Information
No configurations downloaded
Current state: Downloading XML file
Configuration Download statistics:
Download Attempted : 1
Download Successful : 0
Download Failed : 0
TFTP Download Failed : 18
Configuration Attempted : 0
Configuration Successful : 0
Configuration Failed(Parsing): 0
Configuration Failed(config) : 0
Last config download command:
Configuration Error History:
FAX mode: cisco
Running Config
version 12.4
hostname VoiceGateway
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
enable password cisco
no aaa new-model
no network-clock-participate slot 1
no network-clock-participate wic 0
ip cef
ip domain name jjkkcc.com
ip name-server 192.168.1.250
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
crypto pki trustpoint TP-self-signed-2731642326
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2731642326
revocation-check none
rsakeypair TP-self-signed-2731642326
crypto pki certificate chain TP-self-signed-2731642326
certificate self-signed 01
3082024F 308201B8 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 32373331 36343233 3236301E 170D3032 30333031 30303430
32315A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 37333136
34323332 3630819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
8100EF22 8B37729A 73F6BE43 50AB088C EB3B5C5D 38E8A91C E61513BC 1E10F175
2BE25620 39A9DFC8 811E6EBE 13D04CF1 F8FBC2EA 4B7D353C B4B82224 0667B6ED
9E662C26 9B3B9873 09CF4ABA 7C0B7F48 5F820F4A B4D6ABB7 C9D7FA30 7BF394F5
8D918E38 95220282 6B35D73B DD04A506 9C6D660E C9889655 04414F56 049282C4
127F0203 010001A3 77307530 0F060355 1D130101 FF040530 030101FF 30220603
551D1104 1B301982 17566F69 63654761 74657761 792E6A6A 6B6B6363 2E636F6D
301F0603 551D2304 18301680 14B97015 A4BF731B 46B280A8 938521A9 8C1643B2
D1301D06 03551D0E 04160414 B97015A4 BF731B46 B280A893 8521A98C 1643B2D1
300D0609 2A864886 F70D0101 04050003 81810051 0BF18489 4C9D92C2 2FFB7502
0C9BE7A2 056509ED 5DEECDD8 4B70057B 9F4B65CA F3076E76 0469D937 DAC9018B
E31FAC07 7CC2655D FA29ACC3 70C069F9 14CE6AF1 E74C3904 797C0520 63CE6146
82A1BB71 169ABE81 02CF527E DA46C3F6 0540FFE7 2BF494FD B6F20CD9 38250CB6
83920441 ACAC4E8B 01C951F1 A1C31D18 07B092
quit
username admin privilege 15 secret 5 $1$TZgR$FNkiy1bLFvT4W/FmPegTd/
interface FastEthernet0/0
ip address 192.168.1.118 255.255.255.0
duplex auto
speed auto
interface Serial0/0
no ip address
encapsulation frame-relay
no fair-queue
interface Serial0/0.51 point-to-point
ip address 10.1.12.5 255.255.255.0
frame-relay interface-dlci 501
interface FastEthernet0/1
ip address 30.0.36.1 255.255.255.0
shutdown
duplex auto
speed auto
interface Serial0/1
no ip address
shutdown
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 192.168.1.119
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 600 life 86400 requests 10000
control-plane
voice-port 1/0/0
voice-port 1/0/1
voice-port 1/1/0
voice-port 1/1/1
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server 192.168.1.245
ccm-manager config
mgcp
mgcp call-agent 192.168.1.245 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp validate domain-name
no mgcp explicit hookstate
mgcp profile default
dial-peer voice 101 pots
service mgcpapp
port 1/1/0
line con 0
line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet ssh
09-22-2013 01:46 PM
you should add the name as "VoiceGateway", it is the hostname of the router. and add the domain name as "jjkkcc.com"
this will solve your registration issue
Anas
please rate all helpful posts
09-22-2013 01:53 PM
Routers Hostname is VoiceGateway
Domain on CUCM is set as jjkkcc.com
Where should the name VoiceGateway be added, CUCM only give me the domain option.
09-22-2013 02:02 PM
in the domain name write it as the below
Anas
09-22-2013 02:08 PM
Awesome, looks like that did the trick...Las question, why is the IP address blank on my CUCM gateway page for the 262?
09-22-2013 02:13 PM
click on the see endpoints, can you find ip address ?
if you run show ccm-manager, what is the output on the gateway ?
Anas
09-22-2013 02:19 PM
They are there, thanks
09-22-2013 02:20 PM
Hi Jonthan,
great.
kindly don't forget to rate the helpful posts. this will help the community
thanks in advance
