Community Member
Gateway FXS status rejected
We installed a new gateway with a FXS card for fax. Basically i mirrored the config of another router we have configured. Call manager is communicating with the gateway but when i go to "see endpoints" for the gateway, it has "Status: Rejected". Does anyone have any suggestions? I'm fairly new to call manager.
Re: Gateway FXS status rejected
CUCM version?
MGCP or SCCP?
please post your config and how it's configured on CUCM.
make sure the device name is hostname.domain in CUCM
java
if this helps, please rate
java
www.cisco.com/go/pdi
Community Member
we figured it out. needed to be added to DNS and we had the wrong so/su
227
