Community Member
gateway management via CCM
Let me rephraze my purpose from the previous post:
Can CallManager control remote gateway and send to them outbound call to the PSTN and all inbound calls from the PSTN pass through the desired gateway or it's th CM who manager them.
1 ACCEPTED SOLUTION
Silver
Re: gateway management via CCM
All the calls will be routed from Callmanager to the gateway. The first point of call is Callmanger. Next to the gateway and from there PSTN. So Callmanager is managing how the call should be routed.
For third party billing check out:
http://www.tigercomms.com/english/
hth
Ajaz
pls rate the post if it helps.
Silver
hth
Ajaz
Community Member
thanks for your help so i understood that Cisco doesn't provide a billing solution and by the way can you please provide somes links shown some configurations on how the call should be routed by the CallManager
Silver
Hi SEIFEDDINE
Pls see the following link. I recommend it strongly to you:
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00807f54af.shtml
Calls are routed to the gateway using route patterns / route lists / route groups.
Best regards
Ajaz
pls rate this post if it helps
102
