Community Member
Gateway
I have a 3545 PRI Gateway, I can configure this Gateway in the Cisco Callmanger (version 5) to route the calls???
Re: Gateway
If you're trying to use them as MGCP check on this links if they show up as options, i think not
Gateway Configuration (Revised 09/07/2006) 5.0(4)
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/5_0_4/ccmcfg/b06gtway.html
Gateway Configuration 5.1(3)
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/5_1_3/ccmcfg/b06gtway.html
If you're going to use H323 then you can use it
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
Community Member
Re: Gateway
And with a version of Call Manager version 6 ? Is posible configure the 3545 PRI Gateway, to route voice Call?
Re: Gateway
the info should be here
Gateways
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/6x/gateways.html
all i have posted is from the univerCD, you can use it for future reference
http://www.cisco.com/univercd/home/home.htm
javalenc
java
117
