Community Member
Generate billable MOU on PRI
Is there a way to generate a call from a cisco AS5350 that will show up as a billable call? I tried using the csim start command to my desk. This is not showing up in the vendors database.
1 REPLY
Highlighted
Hall of Fame Super Gold
Re: Generate billable MOU on PRI
Csim just doesn't set a calling number, if your SP uses that to mark "billable", they're quite careless.
127
