Generate Translation Pattern Report or view in SQL table
Is there a way to generate a translation pattern report. I do not want to have to do it manually as I have a high volume of patterns. I have tried Route Plan Report but this did not help. I am now looking through the SQL tables but have not found this yet. I have Callmanager 4.1.3
1 ACCEPTED SOLUTION
Re: Generate Translation Pattern Report or view in SQL table
Only thru SQL, there is no reporting on that via CCMadmin, BAT, etc
Look at NumPlan Table, reference value for TypePatternUsage to get translations.
java
if this helps, please rate
java
www.cisco.com/go/pdi
1 REPLY
java
java
306
