Get fast busy signal
Hello. I have next scheme:
Cisco 9971(1000) ---- Cisco 3945 -------- Cisco 2910 --- Cisco 7742G(1001)
Between two Cisco routers I configured dial-peers and it seems to be working (debug voice dialpeer shows success on both routers). But when I call from 1000 to 1001 or vice versa, I get fast busy tone. Could any one provide any suggestions what could br wrong?
Config is simple:
dial-peer voice 1001 voip
destination-pattern 1001
session target ipv4:10.2.4.254
codec g711alaw
And
dial-peer voice 113 voip
destination-pattern 1000
session target ipv4:10.2.4.120
codec g711alaw
Everyone's tags (3)
Output from debud voice dialpeer:
cisco2901#
122968: Oct  4 16:49:47.183 UTC+2: //-1/0893AE5B997F/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=1, Peer Info Type=DIALPEER_INFO_SPEECH
122969: Oct  4 16:49:47.183 UTC+2: //-1/0893AE5B997F/DPM/dpMatchPeersCore:
   Match Rule=DP_MATCH_DEST; Called Number=1
122970: Oct  4 16:49:47.183 UTC+2: //-1/0893AE5B997F/DPM/dpMatchPeersCore:
   Result=Partial Matches(1) after DP_MATCH_DEST
122971: Oct  4 16:49:47.183 UTC+2: //-1/0893AE5B997F/DPM/dpMatchSafModulePlugin:
   dialstring=1, saf_enabled=1, saf_dndb_lookup=0, dp_result=1
122972: Oct  4 16:49:47.183 UTC+2: //-1/0893AE5B997F/DPM/dpMatchPeersMoreArg:
   Result=MORE_DIGITS_NEEDED(1)
122973: Oct  4 16:49:47.859 UTC+2: //-1/0893AE5B997F/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=10, Peer Info Type=DIALPEER_INFO_SPEECH
122974: Oct  4 16:49:47.859 UTC+2: //-1/0893AE5B997F/DPM/dpMatchPeersCore:
   Match Rule=DP_MATCH_DEST; Called Number=10
122975: Oct  4 16:49:47.859 UTC+2: //-1/0893AE5B997F/DPM/dpMatchPeersCore:
122976: Oct  4 16:49:47.859 UTC+2: //-1/0893AE5B997F/DPM/dpMatchSafModulePlugin:
   dialstring=10, saf_enabled=1, saf_dndb_lookup=0, dp_result=1
122977: Oct  4 16:49:47.859 UTC+2: //-1/0893AE5B997F/DPM/dpMatchPeersMoreArg:
122978: Oct  4 16:49:48.195 UTC+2: //-1/0893AE5B997F/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=100, Peer Info Type=DIALPEER_INFO_SPEECH
122979: Oct  4 16:49:48.195 UTC+2: //-1/0893AE5B997F/DPM/dpMatchPeersCore:
   Match Rule=DP_MATCH_DEST; Called Number=100
122980: Oct  4 16:49:48.199 UTC+2: //-1/0893AE5B997F/DPM/dpMatchPeersCore:
122981: Oct  4 16:49:48.199 UTC+2: //-1/0893AE5B997F/DPM/dpMatchSafModulePlugin:
   dialstring=100, saf_enabled=1, saf_dndb_lookup=0, dp_result=1
122982: Oct  4 16:49:48.199 UTC+2: //-1/0893AE5B997F/DPM/dpMatchPeersMoreArg:
122983: Oct  4 16:49:48.523 UTC+2: //-1/0893AE5B997F/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=1000, Peer Info Type=DIALPEER_INFO_SPEECH
122984: Oct  4 16:49:48.523 UTC+2: //-1/0893AE5B997F/DPM/dpMatchPeersCore:
   Match Rule=DP_MATCH_DEST; Called Number=1000
122985: Oct  4 16:49:48.523 UTC+2: //-1/0893AE5B997F/DPM/dpMatchPeersCore:
   Result=Success(0) after DP_MATCH_DEST
122986: Oct  4 16:49:48.523 UTC+2: //-1/0893AE5B997F/DPM/dpMatchSafModulePlugin:
   dialstring=1000, saf_enabled=1, saf_dndb_lookup=0, dp_result=0
122987: Oct  4 16:49:48.523 UTC+2: //-1/0893AE5B997F/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=113
122988: Oct  4 16:49:48.523 UTC+2: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=1001, Called Number=, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
122989: Oct  4 16:49:48.523 UTC+2: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=100
122990: Oct  4 16:49:48.523 UTC+2: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
122991: Oct  4 16:49:48.527 UTC+2: //-1/0893AE5B997F/DPM/dpMatchPeersCore:
122992: Oct  4 16:49:48.527 UTC+2: //-1/0893AE5B997F/DPM/dpMatchPeersCore:
122993: Oct  4 16:49:48.527 UTC+2: //-1/0893AE5B997F/DPM/dpMatchPeersCore:
122994: Oct  4 16:49:48.527 UTC+2: //-1/0893AE5B997F/DPM/dpMatchSafModulePlugin:
   dialstring=1000, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
122995: Oct  4 16:49:48.527 UTC+2: //-1/0893AE5B997F/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     2: Dial-peer Tag=100
122996: Oct  4 16:49:48.527 UTC+2: //-1/0893AE5B997F/DPM/dpMatchPeersCore:
122997: Oct  4 16:49:48.527 UTC+2: //-1/0893AE5B997F/DPM/dpMatchPeersCore:
122998: Oct  4 16:49:48.527 UTC+2: //-1/0893AE5B997F/DPM/dpMatchPeersCore:
122999: Oct  4 16:49:48.527 UTC+2: //-1/0893AE5B997F/DPM/dpMatchSafModulePlugin:
123000: Oct  4 16:49:48.527 UTC+2: //-1/0893AE5B997F/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
123001: Oct  4 16:49:48.527 UTC+2: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=1000, Called Number=1000, Peer Info Type=DIALPEER_INFO_SPEECH
123002: Oct  4 16:49:48.527 UTC+2: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
123003: Oct  4 16:49:48.527 UTC+2: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
123004: Oct  4 16:49:48.527 UTC+2: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
123005: Oct  4 16:49:48.527 UTC+2: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
Hello
Please can you use under the dial-peer codec g729r8, not g711alaw?.
Thank you
please rate all useful information
I tried it already - no use(((
Hi Volodymyr,
Do you have in this scenario, SIP and H323 for calls.
Ckeck in voice service voip (sip to h323 calls, and redirect ip2ip and trust list) features enable.
Ex:
voice service voip
ip address trusted list
  ipv4 10.1.32.0 255.255.255.0
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
redirect ip2ip
Regards.
J Rosa.
Yeap, I have such config already, but nevertheless it does not work(((
I tried to set codec everywhere to the same value but the result is the same(
The configs already in your router, ok! In destination router the config is same or no?
If possible, describe the your scenario CME X CME and attached configs the router A and B.
Regards.
J Rosa.
Bronze
hi
   Did you check whether u can ping between routers.
Can you share the show run from both routers?
Piyush
398
