Community Member
get into the Voice mail from outside
Hello guys I have a question about a voice mail issue. I have deployed voice mail with unity 5.0. We define the pilot number as 4555, now we would like to be able to access the voice mail from the pstn, now we have a did for this purpose.
I try to do it with a translation pattern, but i didn'worked because the dn is not in the call manager, is there another way to achive it with less impact.
Thanks for your help.
1 REPLY
Re: get into the Voice mail from outside
you'll need to reach somehow a translation pattern or a CTI RP and then redirect to unity, then the user can simply press * to get into the sign in
java
if this helps, please rate
java
www.cisco.com/go/pdi
111
