Community Member
Get "version error" when try to register 7940 phone
When I try to register a cisco 7940 iphone I get the "version error" - from research it said to double check to make sure you have the right model phone. I do have the correct phone type specified but still gets this error
When an attempt is made to register a new phone, the Cisco IP phone screen displays version error, and the phone gets stuck in this stage.
This issue occurs when the wrong phone type is chosen on the Device > Phone configuration on the CallManager Administration page. Choose the correct phone type to resolve the issue.
Anyone else running into this issue ? Any advise ? I tried 3 different 7940 phones and get the same "version error". I tried using a template when adding the phone as well as creating manualy the new phone but still same "version error"
What is the Call Manager Version and current Phone load on 7940 phones?
Br,
Nadeem
Please rate all useful post.
Br, Nadeem Please rate all useful post.
Community Member
Re: Get "version error" when try to register 7940 phone
boot  load pc0303010100 / app load p00308000500
tftp load p00308010200
version : 8.0(5.0)
cm : 7.1.5.33900
Re:Get "version error" when try to register 7940 phone
Hi Johan
Try to delete and Re-add the phone back to CUCM and they try to register the phone.
Aditya Gupta
Community Member
Try resetting the phone. Try to register any other ip phone.
Sent from Cisco Technical Support Android App
395
