Get rid of Tone on Hold
Anyone know how to make it stop beeping with Tone on Hold? I tried moving the Tone On Hold timer to 200000, which the info thingy says would turn it off?
Any other ideas?
Thanks all!
Chad
Community Member
Re: Get rid of Tone on Hold
Chad:
The Tone on Hold setting will not apply for H.323 calls.
You will use a blank .wav file to "disable" tone on hold completely.
And assign that blank.wav file to he phones.
Pls rate if it helps
so I actually have to turn on music on hold with a blank wav file? That was my fallback plan but thats stupid. Cisco needs to fix that internally..
Thanks!
Chad
Thanks!
Chad
170
