Community Member
Getting Dial Tone on incoming calls
When a PSTN caller calls a DID in our office, the voice gateway sends a dial tone. Then the caller can press a valid 4-digit extension, then the call gets routed. I have 'incoming called number .' command in our VOIP dial-peer but the voice gateway still sends a dial tone. The configuration for the VOIP dial peer is as follows:
dial-peer voice 9000 voip
destination-pattern 3...
session target ipv4:10.20.30.40
incoming called-number .
dtmf-relay h245-signal h245-alphanumeric
no vad
Please advise, thanks.
1 ACCEPTED SOLUTION
Re: Getting Dial Tone on incoming calls
The incoming called number should be matched on your incoming pots dial-peer not your VoIP dial-peer.
In order for DID to work, you have to configure direct-inward-dial on the pots dial-peer.
The incoming comming called number is then used to match an outgoing dial-peer such as your CallManager VoIP. This is achieved by configuring the incoming-called-number on the same pots dial-peer.
Can you try configuring your dial-peers as follows:-
dial-peer voice xy pots
description Inbound PSTN Dial-Peer
direct-inward-dial
no incoming called-number .
no vad
You may find this document helpful:-
http://www.cisco.com/en/US/tech/tk652/tk653/technologies_tech_note09186a00801142f8.shtml
Hope this helps.
Allan.
Pls rate helpful posts.
1 REPLY
direct-inward-dial
no vad
Hope this helps.
Allan.
191
