Community Member
Getting error Backup initiation timed out. Master agent might still be processing this operation or may be down. Please check 'Backup->Current Status' for latest status. while taking backup
I am using Call Manager 6, error coming while taking backup
I have restarted Master and local agent on all server one by one
I have read somewhere that certificate need to be regenerated
Any idea how to do that?
Everyone's tags (1)
I would pull the DRS legs and
I would pull the DRS legs and check that first.  You can check the ipsec certificate on the publisher under OS Administration->Security->Certificate Management.  You'll want to see if that is expired.  All other nodes in the cluster should have an ipsec-trust that matches the ipsec.pem from the publisher (check the serial numbers).
Purple
Hi Dhiraj, In addition to
Hi Dhiraj,
In addition to what Brian has said[+5], you can also refer the doc .
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-communications-manager-version-71/111796-cucm-drf.html
regds,
aman
