Getting Faxes to Unity
SBCdd7343
Am I correct that in addition to Unity fax integration steps, the router has to be configured for T.37? So faxes are converted to TIF's on router, and then TIF's sent to Unity?
thanks
Brandon Buffin
That is correct. Take a look at the configuration example below.
http://www.cisco.com/en/US/products/sw/voicesw/ps2237/products_configuration_example09186a0080387d62.shtml
Also, be aware that Unity IP Fax is intended for a small number of users and is only supported in a voicemail only environment. See the following link.
http://www.ciscounitytools.com/App_IPFaxConfigurationWizard.htm
Hope this helps. If so, please rate the post.
Brandon
Brandon Buffin
Brandon
thank you very much
