Getting Report of incomming and Outgoing calls in CUCM
Dear All;
I have CUCM 8.5, how can I get report of incomming and outgoing calls using CUCM.
Thanks in Advance ,
Rashed Wardi
Everyone's tags (6)
1 ACCEPTED SOLUTION
Hi Rashed,
Please refer the below CUCM CDR guide,
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucm/service/8_5_1/car/carustop.html#wp1033122
Table 5-5     Top N by Number of Calls Call Types
Incoming
Inbound calls that originate outside the Cisco Unified  Communications  Manager network, enter through a gateway, and go into  the Cisco Unified  Communications Manager network.
On Net
Outgoing calls that originate on one Cisco Unified Communications   Manager network, go out through a trunk, and terminate on a different   Cisco Unified Communications Manager network. For CAR purposes, be aware   that any outgoing call can be classified as an On Net call if it is   configured as such in the CAR dial plan configuration window. See "Configuring the Dial Plan" section on page 29-2.
Hope it helps.
Anand
Please rate helpful posts by clicking on the stars below the right answers !!
Hi Rashed,
Incoming
On Net
Hope it helps.
Anand
Thank you Anada, I will try to implement this configuration ,
4525
