Ghost Image using Acronis Software on CCM Servers
Is there any way where we can install the Acronis Ghost Image Backup utility on CCM Servers, version 4.1(3) sr5b? If yes, is there a document for the same?
Re: Ghost Image using Acronis Software on CCM Servers
it has not been tested so it's not supported, BARS is the only supported app for backing CUCM.
you're free to try installing it hoping nothing will break, if it breaks something and TAC believes it's the issue they won't provide support until you uninstall it and cannot be sure if uninstalling it will be enough to revert changes, worst case scenario is rebuild the server from scratch
java
if this helps, please rate
java
www.cisco.com/go/pdi
Hello chaps,
do you know if GHOST is supported on any CCM/CUCM applications?
Thanks in advance.
The only officialy supported backup method is BARS/DRS depending on your version.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Many thanks!
One more question. Is the same answer for the likes of IPCC? I know unity uses DiRT.
370
