Globally change “15 minutes of computer inactivity” setting on cupc clients?
Hi!
Does anyone know a procedure to globally change “15 minutes of computer inactivity” setting on cupc clients?
I also want to globally change the default setting for “observe status when I’m in a meeting”.
- Rune
AFAIK, it cant be done globally for all clients & needs to be done individually at every client PC.
GP.
VIP Super Bronze
This and a few other settings exist only in an XML file within the user's roaming profile folder. What I have suggested to other customers is to create a logon script that seeds a generic file to this folder if one does not already exist. You have to be careful not to let the script overwrite the file as that would erase other preference changes the user makes.
One other irritating limitation: The calendar integration preference is not in the XML file; it's a database field. Enabling that globally requires a SQL update from the server CLI and must be redone after you add new users.
395
