Good day I need to know how I can switch to the cisco phone wallpaper already loaded.
Without having to go to each phone.
I want it done from CUCM
have you googled it, there is plenty info out there:
https://supportforums.cisco.com/docs/DOC-23868
Please remember to rate useful posts, by clicking on the stars below.
Thanks, but could not find anything relevant.
I'll try tomorrow at work.
Hi Adrian,
What you are trying to achieve is not possible natively in CUCM. This will require a script that you can get developed from a third party or you can check with Cisco Developer network.
Manish
Actually you can with the latest releases, but only on 99XX and 89XX, the topic has been discussed plenty of times before, just as how to try changing the background in bulk, which has hundreds and hundreds, and hundreds of threads here at CSC.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Hi Adrian,
The most effective application for doing anything with Cisco Unified IP Phones (including updating/managing Phone backgrounds) is PhoneView from UnifiedFX (http://www.unifiedfx.com)
You can download for free and try it out, not only can you change background images in bulk with just a single mouse click, you can see the screen of multiple phones at once to confirm the correct image is displayed.
Kind Regards.
Stephen
148
