Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Graceful H323 isdn shutdown
Is anyone aware of a way to gracefully shutdown a PRI for a h323 GW.  I want to perserve active calls but prevent new calls from connecting.
I think the best option would be to shut down the dial-peer preventing new connections from going to the CUCM, however this should not affect active connections. Once there are no calls on the Router, you can go ahead and bounce the Controller.
Hall of Fame Super Silver
I agree with Robert, I usually just use "sh voice call summary" to see if there are no active calls and shut it down then.
Chris
Hi.
I know that is too late to answer this query but an helpful command to achieve what asked is
isdn service b_channel 1-30 stae 2 soft under serial interface.
Hope this can be useful
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
752
