Community Member
graceful power down 3825 voice router & VG224
I've been informed that a graceful power down is not needed on IOS devices such as a 3825 voice router and the VG224's.  I just want to confirm that this is correct or is there a proper power down command to run from IOS in order to shut down a 3825 and a VG224?
Thank you!
"I believe that the greatest work of God has not been in the miraculous, nor in the spectacular, incomprehensible Creation, but rather I believe it was accomplished on the Cross where He Himself purchased the redemption of His Bride... the salvation of m
1 ACCEPTED SOLUTION
Re: graceful power down 3825 voice router & VG224
Hello George
I believe there is no such command grace power down command from cli
You can perform reload or power off button after saving the config .
Br, Nadeem Please rate all useful post.
Hello George
Community Member
Thank you again Nadeem!
151
