Community Member
greeting before answer the call
I have a request that need to give warning message, then transfer to IP phone. Can CUE do that?
Hall of Fame Super Gold
Re: greeting before answer the call
Which system system do you have ? Even B-ACD/AA can do that.
Community Member
but the request is only caller from outside need to give warning greeting to them, internal call is no need.
so, if i use Unity to do this, i think i need to program as below.
CCM side:
translation pattern=93311234 (DDI number)
called party transform mask=1234
create dummy phone with extns 1234, but always call forward to Unity
Unity side:
create 1234 mailbox, but only give greeting and then transfer to x2234 (real IP phone)
Is it possible?
I know that CCM has AA but I can't tell you for sure if it can do that.
For sure, the router can, if used as H.323 GW, without any additional component. That would be done with B-ACD/AA (that is a TCL/ICR script), configure in drop-though mode.
118
