gui for end users
Hi everyone,
I would like to know what is the gui link for the end users in CME.
I want that the users are able to program the speed dials (phone-ui) on their phones.
I know olny the http://ccme-ip/???? part.
Thanks.
1 ACCEPTED SOLUTION
Re: gui for end users
There's no special url
http://router_ipaddress/ccme.html
The Cisco Unified CME system evaluates your privilege level and presents the appropriate window
More info here:
Enabling the GUI
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
1 REPLY
More info here:
Enabling the GUI
java
java
173
