GUI is not working in cme 4.1(0)
Hi Team,
Kindly help on below issue.
Gui is not working, It is showing blank page.
troublshooting steps was carried as follow
1:- i deleted flash/gui files then downloaded  gui file(CME GUI Version 4.1.0.2 ) then i coppied it in flash
CME GUI Version 4.1.0.2 which is compatible with IOS release 12.4(11)XJ and 12.4(15)T releases
Admin_user.js
dom.js
ephone_admin.html
normal_user.html
normal_user.js
Telephony_service.html
xml.template
xml-test.html
2.:- configuration:-
    ip http server
    ip http authentication local
    ip http secure-server
    ip http path flash:
    web admin system name Admin password cisco
    dn-webedit
    time-webedit
3:- CME version ----> 4.1(0)
     Router Platform-->2801
     CME GUI --->Version 4.1.0.2
    IOS --- Version 12.4(15)T7
Kindly find the sho version, sho telephony service, sho flash , sho inventory
and sho run,
  • IP Telephony
Green
Pawan,
On your list of files I think you may have missed one
Can you show the flash
See if you have a file called
admin_user.html
This is part of the GUI TAR from CCO
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
Are your GUI files in a folder on your flash called "GUI" like mine? If so, then you need:
ip http path flash:/gui
412
