GUI Issue
Hello Netpro
I got “CME 7.1(0) Updated GUI files for IOS 12.4(24)T releases” but cannot access GUI interface, no error
page is loading??? for last 10mins, try again same issue. I test on IE 6 / 7 / 8
ip http server
   ip http authentication local
   ip http path flash:
   telephony-service
     web admin system name f99 password cisco
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: GUI Issue CME
The ones in GUI directory.
Re: GUI Issue
Which exact IOS do you have ?
Re: GUI Issue
IP VOICE IOS 12.4(24)T
I get a gray screen with VIEW WINDOW
any clue
Re: GUI Issue CME
Error
Webpage error details, on status bar i get Cisco unified Communication Manager Express but page remains blank
On clicking the ! mark I get this error msg.
Message: Expected ';'
Line: 2567
Char: 14
Code: 0
URI: http://192.168.1.2/ITSMain
Message: 'maxC' is undefined
Line: 2685
Char: 11
Code: 0
Re: GUI Issue CME
Hello
what is ITSMAIN, M I missing some config.
Re: GUI Issue CME
You are not missing anything.
Try cleaning and reinstalling, otherwise switch to YB5 and related fies, I have it working in many sites.
Re: GUI Issue CME
p.bevilacqua Thank You
Clean and reinstall the configuration or IOS Software
what is YB5? I didnt got this??
Re: GUI Issue CME
12.4.22 yb5
Re: GUI Issue CME
Thanks bevilacqua
I am downloading c2801-ipvoicek9-mz.124-22.YB5.bin  but which GUI version for CME do you advice and working with you.
Re: GUI Issue CME
Is this GUI Version OK
cme-gui-7.0.0.1.tar
Release Date:  24/Jul/2008
CME 7.0 GUI file.
Size: 782.00 KB  (800768 bytes)
Which version is working with you???
Re: GUI Issue CME
Not that.
For YB5, the one that comes in the big tarfile for YB.
Re: GUI Issue CME
big TarFile is 70MB and another is 86MB
If you say anyone of these then i would have problem with flash size ( its kinda 64MB only )
If its not this then can you put the exact name or screenshot.
thanks
Re: GUI Issue CME
Extract the GUI files first.
Re: GUI Issue CME
Cannot extract the file on Router, but will extract on a Linux Machine.
What next.
Re: GUI Issue CME
Winrar and many other SW handle .tar on PCs.
Then copy to router and test. Must be used with IOS YB5.
Re: GUI Issue CME
Hi Paolo
What version of IOS 15.x do you know that works with CME GUI 8.0, 8.1 or 8.5?
I'm getting the following error.
Permission denied
ITSMain                                   Line: 1
Code 0                                   Char: 1
URI:http://x.x.0.51/ITSMain
I've already tried a lot of them based on IOS and CME Compatibilty Matrix with no success. Like,
c3900-universalk9-mz.SPA.151-1.Tx.bin with CME GUI 8.0
c3900-universalk9-mz.SPA.151-2.Tx.bin with CME GUI 8.1
c3900-universalk9-mz.SPA.151-3.Tx.bin with CME GUI 8.5
Any ideas?
Thanks.
Re: GUI Issue CME
There are so many files after extraction, I cannot copy all due to limited flash.
Which files to copy to the flash.
Re: GUI Issue CME
953
