GUI of unity express module is not working
Hi Geeks
Is anyone know which files we need to run the GUI of unity express GUI cause recently by mistake i router (which contain unity module also )  flash is erased now i need to access my unity module through GUI can anyone elaborate me which files we must have to run unity express module GUI ..
i will be very thankfull....
Salman
  • IP Telephony
2 ACCEPTED SOLUTIONS
Hall of Fame Super Gold
If CUE works, CUE GUI will work.
Otherwise you have to re-install software on it.
To access CUE GUI you simply go to your web browser to navigate to the IP Address configured for the CUE module... In versions 7.x sometimes you have to write /web at the end http://ipaddress/web
To check the CUE version, you can go into the CUE CLI and issue "show software version"
Jorge Armijo
Please remember to rate helpful responses and identify helpful or correct answers.
-- Jorge Armijo Please remember to rate helpful responses and identify helpful or correct answers.
Hi Paolo
Thanks for reply ....... it means CUE GUI is not depended on any file of flash .??? i can access my unity module through my router how i can check the image in CUE ??? let me know what steps i can take to verify that cisco unity is working fine mean while i will try to recheck the configuration of my CUE may be its have some configuration issues......
Salman
Jorge Armijo
191
