GUI session timeout
Hi all, do somebody have clue how to increace administration GUI session timeout on CUCM7 ? (it is probably the same like on 5 and 6)
Thanks very much in advance
Re: GUI session timeout
This has been a much requested feature, contact you Cisco Account Team and make sure they add you too or create a PER (Product Enhancement Request) for the ability to modify the session-timeout.
Best regards,
Mackers
there is already one, but do get in touch with your AM to add your name to the PER
java
if this helps, please rate
java
www.cisco.com/go/pdi
232
