08-11-2008 04:28 AM - edited 03-15-2019 12:31 PM
I'm trying a scenario of 2 GW's and a GK
Am able to register 1 GW without any issues
the other one is not registering tried no gateway/gateway and debug h225 asn1 & debug ras doesnt gives any output, Able to ping from source IP's
Attached is the config i'm trying
Thanks in Advance
08-11-2008 05:15 AM
What does "debug h225 asn1" reveal? Can you post it?
Chris
08-11-2008 05:23 AM
try to make a dial peer on the MIAMI gateway
and the destination is RSA
to let the gateway register with the GK
i can see u have number registered from biose GW so u need a dial-peer with
session target ras command to let it register with GK
ur config looks good
i think its similer to the config on cisco voice gateways and gatekeepers book :)
also add this to ur GK
gw-type-prefix 1#* default-technology
and do under katekeeper
shut
then no shut
and before u configure the RAS dial-peer on the gate wae
do
no gateway
then enter the
gateway command
try it and let me know
also
good luck
please, if helpful rate
08-11-2008 06:44 AM
There were some config mistakes(the other netpro helped me to fix)then also it was not registering
"need a dial-peer with
session target ras command to let it register with GK"
This was spot on resolved my issue so 4 poits to u
Thank u
08-11-2008 06:54 AM
iam happy it worked
and thanks for rating too :)
