Community Member
GW-GK Registeration issue
I'm trying a scenario of 2 GW's and a GK
Am able to register 1 GW without any issues
the other one is not registering tried no gateway/gateway and debug h225 asn1 & debug ras doesnt gives any output, Able to ping from source IP's
Attached is the config i'm trying
Thanks in Advance
Hall of Fame Super Silver
Re: GW-GK Registeration issue
What does "debug h225 asn1" reveal? Can you post it?
Chris
try to make a dial peer on the MIAMI gateway
and the destination is RSA
to let the gateway register with the GK
i can see u have number registered from biose GW so u need a dial-peer with
session target ras command to let it register with GK
ur config looks good
i think its similer to the config on cisco voice gateways and gatekeepers book :)
also add this to ur GK
gw-type-prefix 1#* default-technology
and do under katekeeper
shut
then no shut
and before u configure the RAS dial-peer on the gate wae
do
no gateway
then enter the
gateway command
try it and let me know
also
good luck
please, if helpful rate
Community Member
There were some config mistakes(the other netpro helped me to fix)then also it was not registering
"need a dial-peer with
session target ras command to let it register with GK"
This was spot on resolved my issue so 4 poits to u
Thank u
iam happy it worked
and thanks for rating too :)
116
